LED Clocks Question
Hi everyone I'm LED converting the zed dash including all of the warning lights, and was wondering if anyone knew the fitment for the 'battery warning light' bulb? All the rest are T5 (and I got hold of some T5 fitment LEDs) but this is a bigger fitment. I've read all the stickies but can't find reference to this bulb (or were to get it in LED form).
Also I have the additional illumination lights along the bottom of the plastic surround. these have a row of flat T5 bulbs where the plastic holder doesn't protrude much. Has anyone found LED versions of these?
Also (I'll post separately for this) but the reason I am soon this is that my indiglo a have failed and I can't find the original clock faces. Does anyone have a set (or a aet of clocks) they want to sell me? It's a 1996 JDM import.
Rich
Just had another look at it. The battery warning light is the same size as the back lighting ones behind the speedo and rev counter.
Does a t10 wedge bulb/led fit into these larger plastic screw/twist lock bulb holders?
Correct T10 is what you need although I have kept with red filament bulbs as the clocks diffusers were designed for this type and I have found no better for lighting up the needles but hey give it a go :thumbup1:.
Cheers man. I'll get some ordered and see how it goes ... or might send them to Groover for the full treatment. Either way need some new clocks first.
