- Replies 41
- Views 4.1k
- Created
- Last Reply
wchestnutt 27 posts
Noz 4 posts
MarkDerby 3 posts
redwine300 2 posts
Hello all,
(I promise I will be subscribing soon after all these Questions!)...
So, my 300 has developed an idle misfire (not bad but noticeable via the exhaust sound). here are the facts....
above 1200 rpm it disappears.
Smooth engine otherwise.
70k miles.
No smoke etc whatsoever.
have had the odd day of it not misfiring at all. but for the majority it misfires. Only started at the weekend after a week of running fine.
Misfires in a regular pattern: hovers at 1k rpm without a misfire for a few seconds, then drops to 750rpm and misfires, then slowly creeps back up to 1k rpm over 10 seconds, stops misfiring for 3 - 5 seconds, and then repeats this process.
When driving normally revs have occasionally stayed at 1.5krpm when the clutch is depressed, instead of dropping to normal... This also seems odd and may be connected?
Have done a lot of searching and I am yet to find someone who has fixed a misfire so I am slightly concerned. I will speak to JeffTT tomorrow hopefully but thoguht I would open this thread for some advice, and also for anyone else that has the same problem as it may help then resolve it as I am determined!
i know the PTU (is thats the right letters) can be naff if it is a series one, but my 300zx is a Jap import from 94 so imagine mine would have been a series 2 anyway... I know injectors or coil packs etc can be an issue, along with maybe o2 sensors, but I am hoping that the specific pattern that the misfire happens on may lend someone some clues??...
It is as if when running smoothly something then overloads and causes the car to drop the revs and misfire, then whilst the revs are lower it gradully gets it signal back to teh spark plugs and they work again until it trips out again...
Liek I say this isn't extreme misfiring yet, but annoying enoguh and I wan't to catch it befor eit gets too bad!
Anyway, rambling now! Here is the video:
http://www.youtube.com/watch?v=8MmvJ7K7ZoU&feature=youtu.be
All the best,
William.
