need help asap :(
Hi everyone just got my 300zx twin turbo auto today and really happy with it. But when I got on the motorway and got over 100mph it knock down q gear I think and smoke went every were, I really don't no wot to do and now the hicas light has come on. Hope someone can help me. Thank you :)
was it a private motorway ? :)
Ok thanks. Bit wot will the smoke be its worrying me as only had the car 5 min
Check the log book and see if Q was a previous keeper, it may have been fitted with and anti camera device thats triggered when you get a bit naughty with the loud peddle
ok ok jokes aside now
you have to remember its a use car thats around 20 years old ... things can go wrong .. what u need to do is check the engine bay for Oil around and try and identify where its coming from but it does sound like it could be power steering related
Mark
Not got the log book yet mate as only just got the car. Do you think the turbo has gone
the powered steering goes all along the drivers side, if it pops on a hot engine it will steam/smoke. Also do you know when the last time the car was actually driven driven, it might just be crap blowing out and the hicas/ps issue is separate. check that fluid level first bud, it fixes lots f hicas issues.
Ok thank you. Just don't get why soon as I go100 plus it drops down and smokes really bad :( could it be a turbo
Yh but wouldn't it be both revs and speed as it drops down and picks up speed. Sorry if I sound a dumb ass
I doubt it, turbo smoke is normally rev related not speed.
the faster you go the higher it revs
ok the pump works off the engine pulley system ... so if u happen to drop a gear this would of made the pump work a little harder and put more pressure on the oil lines to the point if one was a little weak it would of popped ... Hence sending oil on the engine or exhaust system making smoke ..
Haha I no mate not that dumb lol. But that's wot I mean could it be under to much pressure or something. The guy did say one dump value was not working very well could it be that
Got told its a faint blue as my cuzin was behind me, he thinks it could be turbo but we don't don't no.
Take a drive to jeff and mark at zedworld this weekend they will be able to check the car properly,
Sayers
The above is good advice, if its history is unknown it really could do with a quick health check. To put your mind at rest turbo failure either gives you dark blue smoke on boost or white vapour like smoke at warm idle, potentially on the over run too. If it was an isolated one off bluesy black sotty burst I wouldn't worry too much.
Just a thought, dont know about the smoke but if its an import could the speed limiter still be in place? 112mph iirc
20 old car + unknown history + first drive + over 100mph + one dump valve not working = BANG lol
A lesson to all new buyers, get it checked out before you start tearing the arse off it.
Paul
hence why I always tow new cars back if I can then drive them to a specialist. Luckly my new zed has had a good life so no worries apart from a small issue ;-)
