Hicas removal help
ive bought a second hand DW hicas brackets and adjustable arms, but rather than use polybushes i would prefer to solid mount.
Does anyone have a rear hub handy and a set of verniers they could measure for me ?
I need to know the ID of the hole as well as the depth, and i can get some ally bushes made up :)
I dont want to dismantle mine to do it as im not long to go with the welding then sticking it in for an mot so dont want to be left with the hicas broken and the machinists not able to do the bushes quick enough.
any help would be appreciated :batman:
The other ones are 30mm internal diameter so i take it its the same as the other ones in the hub only measured with a steel rule .
