car wont start
hi guys right iv done a manual coversion and put a polished plenum on car turns over fires up then dies checked plugs and petrol smell is there checked the coil pack plugs tpu plug and cleaned and the pump is working any one got any ideas will be handy ted
hi bud that's pluged in may have to put more petrol in as I don't know how much is in there and its still up in the air got to be something simple
more fuel i think thats under pressure so dont think it matters if theres 5 pound or twenty pound of fuel in.
Where to start? It starts then dies.. It wont run even if you try adjust the engine rpm with the pedal? Have you changed injectors?
yea if I pump it, it revs then it dies
have you got the fuel regulator mixed up with the fuel damper ..both on plenum and can be confusing
eerm going to say don't know is the regulator bigger than the damper just trying to think all I can do is change them over
no dont change before you have checked mate with pics and other evidence...it happend to me a few years ago and played havoc with my running
hahaha it ant doing so well now ok ill look at the manual before I do anything
no m8 she a n/a
ok repulled the plenum rechecked the hoses found 2 where air was going in fixed them still ran poor so pulled the maf plug off runs sweet as a nut do I need a new maf? cheers mark for the help and every one that sent messages to get me this far ted
is the maf you're old one or a new one? can you get a spare to try... in case it's the connector or the loom...
and have you cleaned the connectors?
hi yea its the old one iv cleaned the plug when I replug the maf it just cut out took the plug off started high revs but ran on her own steam iv just seen how much thay are but I think needs must
Nope your Maf is doing its job ... unpluging it only indicates the Problem is in another place and on your engine being a NA
not meny places so i would start checking all the Pipes
Idle Control valve all 4 pipes
Air Intake Both sides
PVC pipes
and just for testing Block off the 2 vac lines on Throttle bodys
and the side and balance pipes
all done runs with maf pluged on well happy
also big thank you to markderby for giving me the push forward cheers fella i.o.u a beer or two
thats what i said in the second post you maff ,allbeit it wasnt working i new it was poss a maff prob .anyhow im so glad we all got anabondunce of help on here.
