RichardS ·
25% Off Everything at Opie Oils
Enter Voucher Code MAYHEM and get 25% Off all products we stock from all these top brands:
Amsoil, ArmorAll, Astonish, Bilt Hamber, Castrol, Denso, Dodo Juice, Farecla, Ferodo, Fuchs, Gulf, Hamp (we now also stock the Hamp Shortie), K&N, Kent Car Care, Laser, Mahle, Meguiars, MER, Michelin, Millers Oils, Millers Classic Oils, Mitsubishi Oil Filters, Mobil, Motul, Muc-Off, NGK, Nissan Oil Filters, Oil Safe, Polco, Red Line, Shell, Silkolene, Simoniz, Subaru Oil Filters, Trico, UFI, Valvoline & WD-40.
Take advantage of this offer here > > > > >
We also have many more new products including...
- Filter Removal Tools for Mahle, Hamp, Subaru, Mitsubishi and Nissan filters as well as universal filter removal tools.
- Trolley Jacks & Axle Stands - 2 & 3 Tonne Axle Stands - 2, 2.5 & 3 Tonne Trolley Jacks - 40 inch Car Creeper Board - Wheel Chocks
- Large range of Funnels - For use with Engine Oils, Fuels, Brake Fluids, Coolants & Screen Wash
As always, if you have any questions or need any advice then feel free to ask.
- The team at Opie Oils
