speedo
will a import speedometer work ok in a uk z?.
mine doesn't work properly and would like a working speedo cluster again.
cheers
dave
Should work ok, I put uk into jap, you just need to make sure you put the same series clocks in as the plugs are different.
Paul
Edited by 300_zedx
The speedo will be in kph as the resistor in the UK clocks are different to Jap, you can change the resistor in the jap clocks to read mph, but would also need to adjust the potentiometer on the speedo circuit board
