fiting one piece propshaft
Exhaust may need to come out of the way, but you might be able to just take it off the hangers to give you room. Plus a small brace that goes across the underside of the tunnel.
Paul
Exhaust, heat shield and of course the old prop, to refit the new unit you will need to loosen the diff bolts not completely but enough for the nose section to drop down a little so you can get the end flange cup into the diff pinion.
Note prop is held by 6 x Allen bolts at the diff end
Jeff TT
Jeff TT
Thanks that what i thought :) i would let you know when 2 pcs prop is ready for collection :)
