Water leaky and hicas.
Just seen a post on here regarding the hicas, is there a way of telling if its working? When I bought my zed it had an aftermarket steering wheel on also, so I put back the original one but don't recall seeing a yellow mark or any pins, for all I know is it possible that the hicas on mine is somehow turned off? Second problem is I have a leak when it rains, it's not the targa rubber (I don't think) And both the drain holes are clear. It's coming down the side panel just below the glove box in the passenger side footwell, just in front of the ecu which is worrying.. I've checked the trim on the left hand side which runs down the windscreen And stuck a bead of silicone along the length of it. But it's still coming in from somewhere ..... Also is it normal for water to sit in the gaps around the rear lights? There are fitted correctly.
No posts to show
