driver side acutator pipe
Hi fitting boost controler today can't disconect driver side pipe from actutator any tips thanks
felt like torching hole car today i dont know how your surpose to get your hand in there to dissconect the pipe on the drivers side.Can i use the orginal pipe ive blocked the 2 small pipes coming from the boost soliniod where are the restrictors in this pipe does any one know thanks .
Sure when I done mine I just pulled the alternator off, was quicker and less painful...alternator is easy to get off...
ok thanks terry will take off alternator tommorow and have another go was thinking of taking oil filter of as welll .
Hi spent all day trying to get a silcone hose on the driverside actuator took alternator out still not luck then couldn't get top aternator bolt in took hours had to drop anti roll bar just to get it back in had to cut powersteering belt seemed to be in the way of the top bolt In the end i had to remove oil filter, remove lower steering uj and also remove oil drain then i managed to get it on just it was a nightmare took all day surley theres a easeir way how does the zed centere do it i wonder .
