front hub split joint question
Hi does anyone one know how to split the swivel joint that connect the front hub to the upright arm the bit the top camber arms fit to treid hitting with hammer but no luck thanks taff .
Ball joint splitter will be your best bet by the sounds of it,
Ball joint spliter won't fit it not stricly a ball joint think its called a king pin joint or something .
Yes thanks done it now you have to shock it with a copper faced hammer .
