TT Clocks into N/A
Having some issues with the speedo on the car, I have the clocks from my 94TT will they fit a 95 N/A and work ok.
cheers Paul
they should work if the connections are the same s2/s3 ... but your speedo will be wrong due to NA being 160mph
whilst on the subject do NA clocks work in a TT?
ok, thanks for the replies, will fit them and see what happens.
tomomomtana I will keep your offer in mind.
Thanks Paul
long as the connections are the same the clocks are the same other than being 180mph for tt and boost gauge
Hi Mark, at the moment the clocks are reading about 20mph to much, I think the clocks that are fitted need a speedo converter
or does it need a different speedo face
Paul
Edited by 300_zedx
any of the TT/NA Jap cars with mph Speedo face will need a Speed converter .. Or A Set of uk clocks/speedo unit
i'm sure theres a little mod all so that can be done on the pcb on the back of the main unit ... instead of the converter
I think I just need to find a speedo face that matches the needle position.
I have a 180kpm speedo face fitted to my clocks, looks like this mph one would make the speedo read correctly.
