Door hinges
Hi all,
Does anyone know where I can buy new door hinges? but not from Nissan.
Hop you all have a good weekend! ;)
Why do you want new ones? I have some good condition used ones.
the ones I have , mainly the drivers side are so worn its causing leaks where the window meets the rubber, also its gauged out a groove in the pillar. rather than get them re adjusted which I have a print out of what needs to be done to fix the problem, eventually they too will start to sag, if I buy new, then at least they will last a lot longer than the originals that have been re-aligned. seeing that they are very heavy doors and considering the age of the car 23 years old I would have though new ones would give me less hassel in the long run?
Hi sparx,
Are they new hinges? If so I reckon I could get away with the passenger side :)
The pair? Are they ok, before you took them off was the door aligned ok? Any play?
