egr removal
hi guys is it best to remove the egr as iv got the gearbox out now there nothing wrong with it but as the box is out should I get it out of the way now and I understand its a pig to do as I don't want to remove the engine any help wood be handy cheers ted
Get it done, and the aiv if you havent already. Type in robos 300zx page for some good write ups.
hi bud ill have a look at that page the aiv could I take it away or should I just get the kit and the aiv and water bypass is on the list
since you have access to all the above i would be doing it regardless .. saves doing it later with the box and other things in place
cheers guys we still up for the exhaust mark
wheres that and whats is it for bud
The sensor sits between the two cylinder banks at the back of the block, it's a small black box that detects engine knock or detonation. It's mainly the loom that fails iirc but it's certainly worth checking out and or replacing. May save you having to do the resistor bypass if it fails in the future.
you can not see it or get to it with the EGR in place .. just thought i say .. but once u removed it and u got a skinny/girly hands u can get in there with a 12mm spanner :)
Can you get to if the EGR has been ditched then Mark ? Just in case mine starts playing up! lol
Not from the top of the engine ... only with Box removed and EGR removed u can just get a girly hand in there ..
this is why when it does pack up .. u do the resister mod or buy a new one and mount it on the plenum ..
Damn it! lol Don't have girly little hands, more like an elegant womans... Cheers for that mate.
cheers for that steams so mark when the egr out of the way like that's going to be easy job what do with the sencer and wireing or should I get the egr out the way and get back to you bud so you could walk me through it
get all the egr stuff out the way first ... once u done that u will see a hole between the block & lower manifold .. you should all so see a wire going in to there
follow it with your hand u will see/feel the bolt holding it :)
cheers mark ill go and see about this egr 1st cheers for the info
Vods will agree that i have little lady hands! Helps a lot when working on these dam things.
