Cyclinder 4 Help!
- Replies 29
- Views 922
- Created
- Last Reply
cheshire300zx 14 posts
Baz 8 posts
Stephen 5 posts
welder-sparx 2 posts
Hi guys, having problem with No 4 cylinder. I found last week a knackered injector on no 4, replaced all working fine took for a spin after getting home switched off thinking all was ok. But when i came to start the car again found cylinder no4 down again. Since then Ive:-
Changed the spark plugs.
New coil pack fitted.
Cylinders 2 & 4 coil packs checked against each other on top of the plenum both sparks the same.
Checked injector again hear a clicking sound. injector working.
Changed coil packs over from 4 to 1.
Checked ECU Signal to injector.
Changed ECU.
Just taken all 6 spark plugs out of the engine and all of the spark plugs apart from No 4 are darkish, No4 like new.
Any Help what to check for?
