zed engine
1. Diagnostic check
2. Assuming code 55, determine which cylinder is the problem:
2a. Long screwdriver to listen to each injector firing.
2b. Remove coilpack connector one-by-one. A healthy cylinder with all components working will mean the engine drops on to 4. You'll find the problem cylinder when the engine note doesn't change.
3. Fix :)
