Anyone seen this?
i'd worry when the seller puts this in the advert:
MAX SPEED 186 MPH - 300 MPH ON SPEEDOMETER MORE THAN BUGATTI VEYRON
you'll only really tell from going to look at it mate, plus, the paintwork looks like its based on 50 shades of grey. are any 2 panels the same shade?? Whats important though mate, is what shes like underneath.
and its not a genuine Manual ... its been converted from Auto ..
as if u look all the auto spares are in the boxs & prop
and the joint on the Vac pipework
Manual boost control but no chip mentioned, he talks about it being fast and rwd etc. I bet he has turned the boost up and clashed it about. I quite like the look of the car but shame about the bad paint matches.
is there a big difference between a genuine manual and a converted one?
Mine is a Auto-Maual conversion. I think the only diference is something to do with the Turbos being smaller in some way to reduce lag.
not alot really ..
Cams
Turbos
are the main different other than some pipe work that may not be fitted depending on who did the conversion
Auto Tubs on a Manual car gives a slightly better driving experience .. But will Lack the very top end power but really in the real world not that noticeable
FOR SALE VERY RARE NISSAN 300 ZX 3.0L TWIN TURBO 5 MANUAL GEARBOX ( ALMOST IMPOSSIBLE TO GET MANUAL GEARBOX)
Are true manuals from the factory really that rare??
I know mine is a true factory manual, but if so many autos were converted to manuals, it shows that there was quite a few manuals produced.
I spoke to the bloke and e said he ran it at 16 psi for a 'short time'
As mark said it depends on who converted it, mines an auto shell with a manual box and manual engine, I believe there auto turbos. Wh ws n I first did it, it was quite obvious it wasnt naturally manual. Now its right....youd never know.
Standard Map is around 10>11psi IE Stock boost ..
another above must have the correct Map chip
well going by his pics ... I'd still say its a converted auto as all the auto parts as in his spares box .. plus the pipe work / and balance bar
I've told him to walk away from it, which is a shame as he loves the grey colour.
Fully agree with you why would you have half a prop with some spares unless you need to change it for a manual conversion
