Best Oil?
What's the best oil to use for a jap import TT?
I dont know what oil has been used before,hopefully synthetic.
I've done nearly 3,000 miles so far since I bought it ,when it had an oil and filter change.
Is Mobil 1 best or Castrol Magnatex,or are they all pretty good?
Sorry if I sound'thick',but I've never had a performance car before and this is a big learning curve for me.
Cheers,
F.T.
F.T.,
I used to swear by Magantex, never put anything else in the Z.
Matty.
Hi,
I always used Castrol RS in the Z32.It always seemed OK, and not too thin.Use Castrol magnatec in the Z31 as it's an older engine.
JEZ
castrol RS 10/60, bit hard to get hold of, but apparantly the zed engine loves it
ive used it every 2-3000 miles for the past 40.000 miles,its very expensive but cheaper than a rebuild.
any decent oil would be ok ,just make sure you change it often enough
i would say every 3-6000 miles and dont forget to leave your CAR STAND IDLE FOR 30-60 SECONDS
BE RELIGIOUS ABOUT THIS!!!!
leaving your car running at idle will give your turbo's time to cool down ESPECIALLY AFTER A HARD RUN.doing this will help prevent turbo failure!
IF YA CANT BE BOTHERED OR YOU FORGET LOOK INTO BUYING A TURBO TIMER
I am very careful about my turbos,
I let the car idle for 30 seconds before I first drive it, I then drive 5 miles under 3k and wait for temp to be midway and oil pressure to stabalise before I go into turbos,
last 2 miles of journey I then don't go over 3k, I then let the car sit for at least 3 minutes and I have let it sit for 10 minutes after one thrashing,
whats 5 minutes a few times a day when you think how long the zed could be off the road.
Hi,
I believe there's a couple of different weights of RS, but it was the 10/60 that I used.
They do sell it in my local Halfords, but you can't always find it in a lot of motorist shops.
If you're ever over on the Continent then buy your oil whilst there, as it's much cheaper!;)
