Drivers side loom plug identication
I need some help identifying which plugs go to what as some of them were unplugged when I got the car.
This is the bundle that comes through the inner wing by the brake master cylinder/small fuse box. Im guessing one of the them is for the boost solenoid that was there.
I think B is something to do with the starter or gearbox, I have a vague memory of it going down from there when I took it out
A is to the BMC
Brake master cylinder? Weird, that one was definitely unplugged when I removed it
B looks like boost solenoid and C might be for the cruise doodah.
Pretty sure Baz is right about A too.
Cheers guys, so A is a fluid level monitor?
Anyone know what D is for?
D is for Don't know :rofl:
think d goes in the little box that controls wipers.
Bolts near the little box that controls boost gauge.
Thanks Terry do you mean this one?
That's the boost solenoid next to the giant yellow arrow, all the plugs are different anyway, if it doesn't go in and/or doesn't reach it's not meant to go there :laugh:.
Cheers and yeah I know that smart ass:laugh: Im tidying the loom at the moment and want to keep all the unused connectors in the wing so it doesn't look like a jumble sale in that corner
Not on the main engine loom lol, O2 sensor is the same as coil pack lol, not all are different, but you have to look carefully, wires on the coilpack are thicker. O2 sensor is also the same as the little boost box and also the cruise control, but is on a different loom.
As the loom in question isnt the main loom, id say
A. Break master cylinder connector,
B plugs into the connector for the Positive battery cable,
C is cruise control or boost sensor,
D ??? not sure but looks like that goes into the cabin into one of the pods on the dash? how long is the wire on that loom? or D may even plug into the small fuse box? havent removed that yet so do not know how its wired into the car lol
That is all on the one loom yeah?
Edited by vodkashots
Yeah it's all on the loom that goes from the drivers footwell fuse box between the inner and outer wing to the front of the car behind the headlights then back up between the inner and outer wing to the passenger footwell. All those plugs come off that loom along with the small fuse box.
Im not sure how long it was originally as i've stripped the conduit but they are all less than 30cm from where they enter through the wing
Just under the yellow arrow u can just make out a grey box, sure it goes there mate.
Controls wipers I think lol.
I know the one now thanks Terry
U figured it out,, was it right been ages since messed with the wiring and got my engine bay stripped so I got to remember too lol.
I meant I know the one now you pointed it out :thumbup1:
