Squeaking/ Creaking noise
Hey Guys,
Got a slight issues where the noise comes from the front passenger side wheels. What could be the cause? It only happens when the car is moving slowly after it stops. Its like a creaking of an old suspension kind of sound lol.
Mine has standard suspension with aftermarket springs, any fixes for this?
braking does seem fine though, but it only sounds at slow speeds or when i go over speed bumps and things!
ill have a check
it will be a suspension bushing little dry get some wd-40 and spray each joint and test
its most likely to be the anti roll bar bushing
Probably just as suggested above, however a couple of other things to look at.
Check the wheel nuts, not being fully tight can cause the noise you describe. There was also an issue with the lower suspension arm fracturing at the mounting point for the tie bar this also caused a creaking noise at low speed.
Hi mate, would you have a picture of these locations? srry a bit of a newbie lol
Ok will try and locate that too!
top camber arms are prone to this either fit adjustable ones or spray up bushes
