fuel pressure regulators
Evening all
im after a set of fuel pressure regulators must be working order ,anyone on here got a set sitting around as i'm not sure if this is my problem but i'm eliminating as i go don't mind paying for them but not to much just in case it's somthing else
What issues are you experiencing?
i'm loosing pressure when it sat in the garage i have to turn the key and wait 10 seconds before i can start her up
sounds like Reg is just open as i think one of them has a one way valve in it to stop the return of the fuel
Well if you want them ( Mark@drcorc.co.uk ) is my paypal
One way valve is built into the fuel pump, that maybe where that particular problem lies, however 10 seconds is still a long time to prime, fuel pump ecu can be troubesome.
Jeff TT
they easy to fit mate, i've had a look to see ,looks like you just take the pipes off and un bolt them
already tryed the ecu Jeff got one off you,i sent it back remember as it didn't fix it
sent u pm before ...
but anyways really easy to fit all on top of the engine
one of them and i think its the driver side is just a fuel damper to remove "pulsing" and the one on the pass side is the pressure regulator
