- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Summary
So i started the small project of tidying up my 300zx, hopefully im going to get the interior back to its original state mabeye a small bit of retrimming, all water tight and new t bar seals, take suspension off clean and maintain any bushes around the suspension, led lamps all round and other small bits on the car which can be appretiated to happen from the age of the vehicle. i am doing a small report to get advice on certain jobs and problems. i will be starting with the simpler stuff such as interior and water ingress trouble before getting bigger items done such as brakes or engine work.
Problems
Boosting problem
water ingress
flickering dash lights
tatty interior
spongey brakes
hid problems
tatty number plates
1st day Investigating water ingress trough t bar and damaged of this
so today i started by removing the passenger side interior and lifting the carpet to find all the sound proofing was soaked with a horrible musky damp smell, to follow i noticed some rust areas on the seat fixing bolts, using my screwdriver i cleared away the worst of the rust to reveal a 100mm length hold about 10mm in width and a 2nd hole furthur to the rear about the size of a 2 pound coin. my plans are two simply weld a metal plate in place and treat with rust removal gel and rust primer. im not sure how bad the rust is on the drivers side as that is getting removed next sunday. i knew water ingress had been happening during the time ive owned the vehicle but this was a little bit of a shock but hopefully fixed and treated in a few weeks.
to follow i removed my t bar seal to find that the two corner sections of the rubber seal for the outside of the t bar had bad splits and corrosion not mentioning it was filled with S**T. also the end of the seal where the section above the wing mirror fits to was badly split.
i also checked the drsin tube on the passenger side i poured water in the dran hole but the water did take time to come through under the front wing, im still yet to find the connection to the rubber L grommet although im sure ive seen it on a JefTT thread :).
For the boosting problem:
i took an ecu diagnostics guide from the forum and follwed the steps today the results on the first test was 34 (detonation sensor) the 2nd time it read 55 ( no fault), im thining this is an intermitant fault as the boosting problem is intermitant, whether the water ingress and boosting problem on the detonation circuit are linked i am yet to find out but im thinking of taking it to a zed specialist locally to get the work done , hopefully the ecu diagnostic saved me time and therefor money.
Next week
i am posting this report as i have already had alot of help from the forum but any information you guys have on zeds is greatly appretiated so hopefully i can learn alot about the machine and become as useful as others at helping people with there cars. :)
i am rather new to the forum but will try and get some pictures up of work happening in the future once i sort out a photobucket account.
Marlow TT Cornwall
