Interior light problem
Interior light problem on Artztogo 300zx
thought it was Door Switches .. but been changed and still the same
Symptoms is all works fine lights on off with door open/shut .. but leave it for 10>20mins and the lights come on by them self ?
can any one shed any light on to this .. lol
  • Replies 36
  • Views 838
Ive got 2 normal bulbs and none of them are working. so i went direct to the battery and they worked ish. so i poped the led in it and it worked then poped it back inside the car and it didnt so i thought there was no live inside lol!!
I cannot figure out what wire to tap into to make the mirror lights and door handles light up when the fob is pressed??
the wires to the siggy light or the wires going to the light around the ign key think would be fine
My slicktop interior light comes on when boot open i have no boot light at all do all swbs get no boot light then .
Correct for some strange reason we didn't get one, although I have put one in and another that incorporates inside my amp build :thumbup1:.
All sorted now and looking good. Even got foot well lights now. Very classy lol
we replaced all relays and control unit but the problem still remained .. however we did find the problem in the end ..
at the time fitting all chris lights all was working unill this problem
found out later that he tuck the Normal Bulb out of the center light
as it wasn't "blue" well i kinda wasn't told this
well it turns out that the control unit needs to sense some small Load
from the internal lights ..
as all lights have been changed to LED bar that one
so just to recap .. use normal bulbs or LED that are load/volt type
Yes the low internal resistance of the interior light led was the problem by changing it for a normal bulb or a load resister the issue was sorted I showed Chris this when it was with us a month ago just needed the bulb changing but would you know we did not have any!!
Jeff TT
Edited by JeffTT
