Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 13k
the block is being treated and checked ... other than that nothing more really is needed
not even going to say this time ... as last time i said i got slated but still the engine i have now is more than capable of the power i said ... just the tuning was letting it down
before i was looking for 550>600 but only made 477whp@16psi works out around 520>530 there abouts but this was on the standard ECU/andyP chip
My Tuning guy .. in hinkley
Well depends on the funds think i could afford another turbo kit
but my ones are rated at 700>750whp
What about the issue with thin walls, big power and melting? Been issues with this in the states worth looking into what people have done to address this when it comes to 90mm pistons. Or just speak to Kyle Puckett
This article may be of use to you - under "The Engine Block" section regarding overbores, cryo treating, epoxy filling water jackets
and torque plates.
http://www.modified.com/projectcars/9909scc_project_nissan_300zx_part_4/
Hope this helps some.
-Andrew
Edited by AndrewG
Hi Mark, you should do Ten of the Best once you're done, maybe a round of TimeAttack?
thats the Treatment Cryo& Xray i'm doing
and torque plates.
-Andrew
Same as above really but not filling the water jackets
indeed i thought about it :)
these are the New turbos i'm thinking of getting .. Speaking to CPZ today and they said ( when testing they had over 800whp from them ) he sugested the GT2871r they have higher output but he said the Lag was rubbish
$2965
This Turbo kit uses a GTX2863R Ball Bearing Turbo. This turbo kit is great for the Street and Drag. Reliable Spool up with a little extra kick to it. This kit is a direct bolt on, no modifications needed. 700+ RWHP is possible w/ the correct tuned setup. A 5-bolt downpipe is required, as the OEM downpipes are only 4-bolt and will not fit.
What's the overall aim of this engine build Mark, are you looking to crack the 1/4 mile sub 11 seconds?
prob with no audio in the car ... i tuck it out the other month all i can say is .. its fooking heavy need to weigh it up
My Wife only agreed for me to get the new tubs and other parts ... the agreement was this
Edited by MarkDerby
Couldn't imagine the drive ability with a pair of 2871r's I had the 2876r on my s13 that use to hot full boost by about 4.5k so would be slightly more laggier on a 300,
But then it's all down to how you drive them if you can keep them on boost most of the time it would be an animal
funny thats all most the same as what cpz said about them
he recommended the GTX range due to having a Billit alloy comp so spoooooooooooling time was less
Mate that is a WIN-WIN agreement in my book! Cute little boy there:thumbup1:
Look at the 1/4 mile leaderboard and then look at how much cash has gone into them zeds sub 11s 15k with a vg I would say and not on a manual box
th400 gearbox that`s what you need :)
