Will these sizes fit on a Zed
As per title, how would they look and what tyres sizes would you recommend.
2 x 18" x 8.5J ET 25 5X114
2 x 18" x 10J ET 25 5X114
cheers Paul
cheers Paul
If you know what size/offset your current wheels are you can dial the figures into an offset calculator that shows you how much further in or out they sit (as a dimension)
  • 4 weeks later...
Just following on from the first post (I didn't feel that my query warrented a new thread)
17" x 8.5" (ET 30) front and rear
Only to be used for second set to run wet tyres (235 front/255 rear)
thoughts please?
Fronts easy (I have 9.5x18 ET 22 up front and fit fine) rears will need a bit of work though due to the offset. I'm running 10jx18 ET 38 at the rear with 295 rubber and deffo needed arch roll
Oh, and I'm only running 0.7 degree neg camber at the rear
i have 10jx18 et 36 rears with 285 35 tyres no work to arches done and no rubbing ... 8jx18 et 38 fronts 235 40 tyres 15mm spacers but would look better with 25mm spacers
Have you had to dial in crazy camber to fit them fronts in? Any pics?
I have 17x9.5 et38 with 275/40 tyres on the rear and they sit flush.
