Hi ive had some front adjustable camber arms on my zed for around 5 years now .I take them off once a year to clean and re grease but one side is squeaking.The bearing seem to be running dry, rough sounding and course to spin .Can these be replaced think there z centre ones thanks taff.:biggrin:
yes i have replaced the ones in mine, easy to do but make sure you use a little loctite on them when you put the new ones back in.
bearing cost about £30 for both sides from a local supplier.
i had the exact same problem as you have , the squeek was driving me nuts!
wow ... £30 for bearings ....
pop the bearing out and search on the net for the size u need
ok thanks guys will put up with squeek at moment to cold and snowey down south thanks taff:thumbup1:
