Need to find a live connetion when ignition is on..
As the title says - can anyone tell me which wire or connection (near the fusebox) will be live when ignition is on, so I can tap my DRL power feed into it. Something easy to get to would be ideal.
Rich
Probably starter relay, starter, any of the big fuses near the bmc.
Black/red from the ignition switch. It stays live while the engine is cranking aswell
Appreciate that guys - however what I am really after is splicing in to one of the wires going to the multi plug connections just below the fuse box... otherwise yeah I will have to get to the ignition barrel or get underneath the fuse box to make a connection. It's not easy to get anywhere to connect my test meter to find the ignition live near the fuse box otherwise I'd find it.
Rich
