Waterless cooling system fluid
It is often used in light aircraft with Rotax engines. Got a bit of a mixed reputation. Unless you have a really good cooling system then you will see higher temps and need more pressure. So if like me you have a bigger radiator - but have not uprated the engine much it should be fine.
there has been posts on this before they used it on a classic car rebuild on the tv a short time ago
