buzzing noise, engine off while opening throttle
i want to find out what this buzzing is, with the engine off and pressing the throttle there is a buzzing noise coming from the back of the engine....
what could it possibly be please?
sorry matey i didnt mean it to sound so blunt, why i said it was because i thought they wouldnt be active untill engine running and over a certain rpm?
take the plugs off em Gaz..just to rule them out
Fuel pump ? Mine used to buzz when I turned on the ignition but before ignition. Not sure if it did it when I press the throttle though..
with the engine off and pressing the throttle there is a buzzing noise coming from the back of the engine....OP,s own words mate
yup deffo not fuel pump as that is in the tank at the back of the car, this is behind the engine.
will do, its just strange as it is activated by throttle position, the tps adjustment was out and i set it back to .45 volts, im wondering if it could be a faulty sensor...
Hellraiser, i never took it as you being blunt, the answer was short because I was going out. Hope you find the problem soon.
cheers Paul
Today i got my mate to have his car with just the ignition turned on and i slightly open the throttle and there it was "the buzz"...never noticed this on my last auto zed i had but this one does just as Gary has said...the good news is this paticular car runs 100% spot on so theres nothing to worry about.
Yup, mine has always done it too.
