Only firing on 5 cylinders
Not my car but mate with the black wide arse..............cylinder 6 is not firing...ptu?????
Dave
i would check all leads anyways
but as its cyl6 this is very common for the piston to fail/melt
and give u misfire symptoms
but check all plugs/wires first
Checked every thing!!!!!!!!! we did find missing spark plug tip and thought great....but no still same looks like heads off then:ohmy:
Do a compression test. As said no6 csn be a engine killer.
Doing this tonight
missing spark plug tip on cyl6 ? if so it will defo be piston with bits of alloy being chucked around the bore normally damages the plug
No not six opposite side...and thats fine:blink:
still strange ,,, but cly3 still can have problems with heat ..
well best thing to do is get a comp test and go from there before we start saying this and that more
Thanks Mark car is at mine and just spoke to him so will do this on the weekend.
Thanks for your help.
Dave
Check You got a spark there. Remove no.6 coil pack put sparkplug in, touch any ground in Your car (example - body) with end of a sparkplug (this little tip), and try start Your engine (but dont start it :P ) . If You see spark - start to worry, if not - You know whats wrong :) .
I hope You understand what i mean :P .
Check for spark as above.
Check for fuel ohm the injector or do jimmers trick.
Compression test.
If you have all the above timing is the only variable.
UPDATE My mate called in lunchtime with a stethiscope and listened to injectors found the one for no 6 not going .....cleaned connectors all running sweeeeeeet.:clap:
Thanks for all the guidance:thumbup1: he also asked me to tell you much appreciated for help.
Dave
Good news, more often than not it's a cruddy/broken/duff/old/brittle/loose etc. etc. connector :)
