The old hesitation/stumble issue again - cold starts
- Replies 31
- Views 6.1k
- Created
- Last Reply
mrrossi 12 posts
Noz 7 posts
Medallion Man 3 posts
phutumsch 2 posts
Popular Days
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi
I know there's loads of threads about the stumble/hesitation issue that seems to be a common problem in the 300ZX, and I think I've read them all, and tried most of the suggestions within them, but I'd like some advice please.
I have a 1992 UK 300ZX twin turbo, with a +70BHP EEPROM upgrade and Apexi air filter.
The previous owner had the car for 9 years and had the EEPROM upgrade done when he first bought it. He thinks the stumble first started about 4 years ago but as he 'drove her like a granddad when she was cold' never really bothered about it.
My particular stumble/hesitation ONLY occurs in that first 10-15 minutes. Once the car is fully warmed up, it doesn't happen at all.
It seems to happen mainly when I'm doing 30mph or so in 2nd, or 40-50mph in 3rd, and the revs are between 2500 and 3500. It feels as if someone has taken the accelerator away for second, then it comes back. It may do it once or twice in a few seconds then it'll be normal.
Seems to do it mainly when I'm at that constant speed (30mph zone) but occasionally will do it when accelerating.
Even in those first 10 mins or so when it's still cold, it doesn't seem to happen at higher speeds/high revs.
Every so often it's more severe, and the 'drop off' will last longer than a second and feel likes it's going to stall. It did this really badly tonight. The car hadn't been used since this morning (2hr run, little bit of stumble in first 10 mins then absolutely perfect). I took it to the shops 9 hours later, 10 min journey. Stumbled maybe four or five times, not too deep, but annoying nonetheless. Shopped for 10 mins, came back, drove for another 5mins to another shop, couple of minor hesitations. Shopped for 20, maybe 30 mins. Got back into the car and headed for home, about 2 mins in had major, deep, drop offs, felt like it was kangarooing - would get 2 second without power, 2 seconds normal, repeated, probably about 10 times. All the time my foot was on the pedal consistently. Came to a roundabout and stopped for a sec; pulled away and was fine again.
Outdoor temp today has been 12 degrees, so not that cold really.
I've been following this document for the last couple of months and trying different things out:
http://www.zhome.com/ZCMnL/PICS/hesitation/hesitation.html
So far I've done:
Unplugged everything - injectors, all connections, cleaned all contacts up
Checked PCV hose/values (clamped as best I could, not fully closed, but there was no fluctuation at all)
Air flow meter - voltage fine
Air filter looks clean enough
Cleaned throttle intake valve
Voltage checked TPS - adjusted to 0.47V
Cold start temp sensor voltage check (readings here http://www.300zx.co.uk/forums/showthread.php?165253-Coolant-Temperature-Sensor&highlight= which I think are fine)
Checked spark plugs - have the correct PFR6B-11C, they look relative new/clean
Replaced Series 1 PTU with a Series 2 PTU
There are a few more bits and bobs that I could chec:
OHM check injectors
Replace fuel filter
Fuel pressure tests
BUT, reading through that doc above, and other posts, they don't sound relevant to my particular problem - i.e. the fact that the stumble is only when cold (in those first 10-15 minutes).
Any more ideas anyone?
Reluctant to spend any more time/effort/money on her!!!
I AM off to Zedworld in Birmingham at some point in the next month or two to replace an air compressor, I could ask them to take a look, but fear it may take them a long time (and cost me a lot!) to diagnose.
I thought the EEPROM upgrade could be to blame but it was installed 9 years ago and it's only been happening for the last 4 years...
Ross
