what bumper and headlights?
anyone seen this before, particularly the front bumper and headlights and centre panel?
anyone know who made's them?
kinda put some ideas in my head. really tempted to get the fibreglass out and see what i can make... really like the ideas of the headlights.
  • Replies 37
  • Views 1.4k
im going to put a indicator/ sidelight in there too so that i have no lights in the bumper at all.
I wonder if you can use one of these, I have been watching it in my ebay for a while now and I do wonder if it will go in down the outer edges rather than on the front parallel with the ground :yes: one thought though, does the indication need to be seen from the front and side on and with this unit under the glass would it :huh:.
http://www.ebay.co.uk/itm/110932341504?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
MOT thingy states
"The precise position and angle of visibility of direction indicators are not part of this inspection, but they must be on each side of the longitudinal axis of a solo machine. If a side car is attached, the indicators must be on opposite sides of the combination."
so assuming its visible from the front and the repeaters work i should be o.k.
but i like that idea,
i have put indicators in my headlights but you cant really see them until there on. i sunk crome bulbs in there two on each side they look sweet i done this when my headlights were being cromed.
Can you take a pic of this little mod - be nice to see :clap:
the 99 spec is currently off having the splitter fitted properly and painted.
ill probably just make a pair of ducts like the car.mad ones i currently have but to fit the indicator hole,
only had it painted a few months ago so wont replace it just yet.
unfortunately took longer then expected to redo the side to get them sitting right, so haven't finished filling smoothing them, but.....
what do you think? worth carrying on?
Not against that at all, when that's sprayed it will look 100 times better still, can you just dollop a bit of body colour on it or black?
I think they could look really sweet!!!! Keep going, might be interested in a set!!
Im liking it, as Phutumsch said if you can spray a bit of colour on it quick it will help see the contours better
Won't be any good for aerodynamics, but might be good depending on the finish. Definitely different
