turbo coolant line layout
has anyone got photos of teh stock turbos with all the coolant lines attached, i didnt think it would take me this long to get this far and ive forgotten which pipes go where. and which direction etc
Stock Layout or with Plenum bypass
this pic is bypass routing
irrelivant i nee dthe photo of the tub itself the hard lines that come off the core. :)
what do u mean .. how the vac line runs ?
Main vac line comes from Inner hard boost pipes each side of the rad
then just below the Over ride valve theres a small Y Pipe
it connect to main vac line then to Actuator and other side conects to the over ride valve on the Inner hole
the outer hole gos to the Turbo intake pipes
Edited by MarkDerby
no i mean the little piece of sheet metal with the acuator or solenoid on, what they bolt upto had a quick look at them this eve and neither side seems to want to go on. :s
yeah and ahh that picture helps i assumed it bolted onto the turbo housing, that why it didnt fit there then.
