New turbos
Can anybody advise about turbo upgrades. I have a smokey cylinder bank which I pressume is a turbo, however need to confirm yet, is it possible to do a turbo upgrade for under £600. Will 200sx turbos fit as I have seen them for as little as £180 on ebay.
Yep the t28 from the s14/14a and s15 t28 will fit so will the pulsar t28 but you will need to rotate the turbo housing, you'll the need 5bolt elbows and need to make up some custom actuator brackets you will also need a t28 fitting kit from somewhere like czp
You wil also want larger injectors to make use of your larger turbos and trust me you dont wanna fit secondhabd unknown units to have to refit as its a pain in the ass mines currently going through this. Have you done your pcvs?
What's a pcv?
and inlet flange adapters and Outlet 3 bolt hose flanges are different too
a little valve that controls the pressure within the crankcase if they fail they can jam closed causing back pressure on the tub seal that forces oil out because it cannot pass into the sump properly. if failing open it can pull oil in from the rocker cover which burns. its worth going through the intake tract to check for oil and changing the pcvs will cost you about£70 to change them. my cars currently got its engine out with the tubs being replaced. hence why its not been around recently, and oh weve moved lol to bournemouth. gimme a shout if you need a hand as you can imagine though im pretty short on time atm due to my own project.
Only think i can highlight here is the S15 is a T28R matey
Thanks for the info mate, will have to catch up with you soon, only just finished skills
Oh yeah thats good def catch up soon, il be around a fairbit visiting family still so. Infact im there tonight for my mrs mums bday sbut obviously cant do anything.
