Abs
HI,
MIght be a silly question but do all 300zx come with ABS? i have a 1990 jap one.
HI,
Not all of them
There are base/lower spec NAs without it. Especiallly 2 seaters.
well mine is a twin turbo, so guessing it should?
It should have but it might have been removed by a previous owner. Quick way to check is to look at the Brake master cylinder. If it has two outlets then you have ABS, if you have 4 then it doesn't. The ABS pump is located in the boot drivers side under the suspension turret panel.
Yes that zed has ABS, go for a drive to a quite road or better yet empty shop carpark, get up to around 40mph and brake hard, you will feel it kick in, you dont have to be going too fast to test it.
As Voddy says, your car will have ABS......
....all twin turbos did; and most (probably) n/a cars did as well; although I do know that some n/a cars did not have ABS.
Richard:cool3:
