rear speakers
Spritley there really easy to do ... pull the covers off by grabbing the edge thats inner of the boot and pull it up ...
then for speakers are fastend in by 4 screws
Speakers are 4x6 size
cheers mark but want to replace with aftermarket ones not crappy bose and mine seem a bit large does the whole pod have to come out as well and something fabricated
ok u have the bose pods ... u will need to take all the boot trimming off
theres a few screws behind the rear seat
and the side covers close'st to the lights are bolted and pop on
yep mark correct just found out i need some other speaker mounts non bose ones will se if anyone has any on here
the bose Pod units are far better than the 4x6 speakers normally fitted ...
but if u still want the Mounts for them i can so u the set for £20 Posted
cheers mark can u actually buy the replacement bose speakers then will let u know about mounts tomoz
na there will be all most worn out by this time now ... Normally perish around all the edges
you can fit another set of after market 6.5" in them ... but all so does depend on how your head unit is wired up to them
as the bose system have Mini Amps built in .. if your on Stock head unit then just replace speakers ..
if u have after market head unit then it would be best to make sure there wired directly not vir the mini amps
due to most New head units will out put more watts per channel then the original bose system
cheers bud its a aftermarket head unit but its wired to the bose speakers with the amps to do it right i will have to disconnect the amps for some aftermarket speakers
yes and no ...
the Bose box's have a mini amp in them but its only like 15watts Per box ( channel ) .. kinda crap
but this was to get around the Standard head unit low output to over come the rd noise in the rear of the car
where as your after market head unit is more like 25>35watts Per channel it would be wise to by pass the mini amps and wire direct to head unit
for better sound and out put
I've now got the bose speaker box's fitted in the rear, found it a chew on because i couldn't remove the rear seat. but it was totally worth it in the end.
I bought these speakers form ebay
http://www.ebay.co.uk/itm/150761829836?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Service was excellent, and they sound great.
These for the rears or doors? also any modifications needed?
I've got them in the rear in the bose speaker box's, direct fit. And they will fit the doors too with slight modification.
DSC00138.jpg[/img]
DSC00137.jpg[/img]
The speakers in the picture aren't the same as the ones in the link, although they are the same size.
DSC00138.jpg[/img]
DSC00137.jpg[/img]
Is the first and second picture the same speakers with some grill on top?
yeah, I made a black rubber gasket to cover the whole left from the original speakers and then fitted a 6x9 grill to cover the seem. all held together with a couple of BA bolts
