Low idle, stall, LIGHTS and buzzing!
- Replies 30
- Views 5.1k
- Created
- Last Reply
EvoluZion3 11 posts
redwine300 6 posts
groover 2 posts
Medallion Man 2 posts
My Z has deteriorated overnight. To follow on from my previous thread - basically from the start of this week she's been driving like sometimes she's on 5 cylinders. Once the engine warms up, she misfires a little and holds back a bit when I accelerate from low revs. She boosts ok, although now sometimes she'll judder a bit as the revs go above 4k. Don't appear to be symptoms of wet MAF as I've had that loads of times before (revs just cut under boost).
Anyways yesterday afternoon on the way back from work she started to buzz loudly whenever I took my foot off the throttle. The sound seemed to be coming from behind the dash, but I confirmed this morning that it's from the driver footwell.
I went out today with the hope of fixing the misfiring - I taped up a couple of cut/bare wires, pushed the coilpack plugs in firmly, checked the ECU temp sensor, the plug to the CAS and TPS, and had a general nose around the engine bay. I also taped up the connections to the PTU (which is relocated and exposed a little to the rain under my nose panel) and fired her up.
She idled ok for a couple of minutes, then as she warmed up the revs dropped to 650 and she started to struggle idling. She revs ok (but hesitates a bit), but if I rev her over 4k or so, once I take my foot off it'll drop and stall. No visible smoke from exhausts, although yesterday there would be a puff of dark grey smoke on overrun.
The LIGHTS warning light has started to come on which it never has before, and when I rev the engine, or switch the fans on, then off, there's a loud buzzing from the driver's footwell, around the fusebox area - like a failing solenoid perhaps. From cold, the LIGHTS light would flicker quickly 'in time' with the buzzing, but then it stays on.
Video is here:
Any ideas as I wonder if these symptoms are connected somehow...?
