Hi guys, I`m still having trouble :( car is stuck on the drive again and wont start!!! ahhhhhhhh ..booked into zedworld on Friday morning
I`ve got a fuel pump ECU getting delivered tommorrow, and I really hope its that, but previously where i could hear the fuel pump, there is no sound at all now?? I know everyone says the fuel pumps don`t go wrong, but I do really think mine is goosed!? could be wrong and could be getting paranoid now
anyway where`s the fuel pump on a vert (swb)
Under the flat cloth tray in the middle of the car!!
Thanks again Pete ;) its weird!! as it did sound like its coming from under the car :)
You could remove the fuel pipe in the engine bay and see if its pumping fuel. Maybe the pump has given up.
yeh, that`s 2morras job :( getting fed up now :(, thanks Phil :)
Alternatively we could hook up the datascan again and try toggling the fuel pump to see if it kicks into life.
You should hear it briefly when the ignition is on to prime the fuel lines
Cheerz Phil, I will have a little play in the morning and let you know ;), I`m probably going to do the ecu bypass, to hopefully get me to zeddy world, if the pumps knackered then I don`t know what to do :(
Thats a good idea BUT even if it has fuel coming out you really need to know if the system is developing the correct fual pressure to run properly. You really need a fuel pressure gauge to drop in to the line to check that.
Its not the relay is it dazzler?
Gonna check that too tomorrow bazza
Swap it with any green relay from your TT, or just bypass it to see if your pump is pumping :)
