Its Broken ... i must have the worst luck going when it comes to cars !!
Take a look at these pics ...
but on the other hand the nissan is doing fine :) haha
this is from my Mondeo after my AEM water injection kit decided it wasn't going to play right ..
the injector that sits on the engine had a anti drip valve .... guess it decided it didnt want to work any more
was parked on a hill nose down and it let quite a bit of Meth/water in to the intake on the Mondeo
and Now i have 3 bent Con rods this is all so what happens to all Diesel cars that ingest water from flooded rds
the symptoms are normally Bad running loads of unburnt fuel looks like is steam engine when it run .. loads of Engine Knock
miss fire eerrmmm
it didnt fail when it was being used .... or even using the meth it was the aem kit the valve stopped working and it let about 1lt of meth/water in to the intake system
the engine jammed on of turn of the engine and result is the bent 3 rods
oh these are forged rods and pistons as well
its a PSA engine not the Puma. that fails .. these engines are kinda bomb proof beside the injectors but thats the same on all modern diesel cars today
that funny i always thought they were crud engines too, we had one at work done like 40k regularly serviced you know fleet car. dropped a piston. and when we were looking for a focus we looked at diesel ones and were steered away as the ford diesel block had a bad rep.
but obvioulsy this time it wasnt related to the block it was the other part failing. but yeah.
the only known faults that i have delt with over the years of owning this one and helping out are
Dual Mass Flywheel ... and Transit are well known for failing at such low mileage
Fuel Pump eats its self and in turn takes out the injectors
or just the injectors normally failing around 80k
Rubber Boost pipe splitting
i still have my original injectors & turbo with 110k on them .. and still running the original pump,block,heads,gear box ...
how ever i have to buy a new DMF this time as after 60k theres to much play on it
but like more diesel cars .. have all most the same problems
Edited by MarkDerby
  • 4 weeks later...
workshops..dont you just love em,a mans place of solitude:thumbup1: When's the start up?
Tuesday just gone ... bit of a bitch to start/prime as theres no manual fuel primer on the car and no electric fuel pump in the tank
fitted
New Rings
New Main Bearings
New Big End Bearings
2.2 Pistons on 2.0 Con Rods ( Better burn room )
Slightly thicker head gasket
New clutch and DMF
New Aux Pulley tensioner
New Crank Pulley
New Engine Torq Mount ... as the old one is Bent ..
its all Running now ... and very smooth
