gearbox woes...
When trying to attach my manual box to the car after replacing everything bar the kitchen sink under my car, I get to within an inch or so of the block and no further.
I've installed a pilot bushing into the back of my crank, but in hitting it in it seems to have shrunk a little?!?! I've measured the inside of the pilot bushing and it's now 1/2mm smaller than the input shaft on the gearbox?!?!
I'm now stumped, has anyone else come across this.
(i'm converting from an auto to a manual)
Cheers.
'I hope I die peacefully in my sleep like my Grandfather and not like his
passengers....'
Fairly common if the engine has also been out - possibly even if it hasn't..
You may find the engine has tilted a little, and that you need to raise the front of the engine (engine hoist, might be possible with blocks and a jack) to tilt the rear down a little, and then it should slide on..
I haven't measured the bushings like that - but it seems to be a common thing that people can get the gearbox *almost* on, but not quite..
GZ.
cheers for the reply!
I've done the tilting thing with a jack under the sump, it was plum straight with the gearbox. The interesting thing is that the pilot bushing was an **** to get in, so me being a bit rough with it has probably deformed it.
Anyway, i've got to box on and everything connected up, so i'll take it for a drive tonight and see if I get any vibrations.
I'll probably get a garage to put a new one in in the near future just to be sure. (let someone else have the aggro!) wink.gif
