Fitting new turbos, what do I need to know?
As above, engines gonna cone out as im sure is turbo failure. Now once its out. And theyre off rebuilt etcwhat do I need to know? How do you prime them? How do I check the oil ways etc. the more comprehensive and info laden
The better :)
if the tubs didn't come with an Oil primer kit .. then just use some engine oil in a oil can and put some in the tubs where the oil feed goes or ..
with your Cas disconnected turn your engine over few times the engine will prime its self and tubs
reconnect and away u go
cheers mark havent brought them yet just wanted to fill my head with usefull information before i got that far. id raher know it all now than be asking question with it sat in my hand, makes life much less stressfull.
personally id use it as an excuses to do a few other bits on the engine, rear main seal etc.,
and id go with new lines on the turbos, or at very least replace the oil return rubber pipes, and don't forget all new gaskets, and the oil return pipe one.
could just remove he fuel pump fuse and crank the engine as an alternate method if you don't have a primmer kit. but id do it a fair few time, and then would break them in carefully, personally left mine running for ages on the drive, before finally taking it for a drive.
rear main seal has been done when i did the manual conversion about a month ago. gonna do the egr delete and rocker covers whilst out. water bypass etc. is it worthwhile or possible to clean the feed from the block? to make sure they are getting oil?
i dont have any reason to think i have an issue with it just you know taking the opertunity to do things right. :)
