pump ecu replace
i have to replace my pump ecu ,,how hard is it to take off the side trim by the rear seats under the window passanger side,,will i need new clips ?
easy job... can't remember exactly as it was some time back but I didn't need new clips....
there are a few screws to undo and I think you may have to take the rear seat out as well.... have a look in the Service manual...
dont have a service manual i tend to wing it lol cheers for that will have a go if it stops pissing down
Its not that hard, in fact when I changed mine I didn't even have to remove the whole panel, i just loosened it off enough to replace the ecu. think you'll need a 10mm spanner/socket and a couple of screw drivers.
