Number of stuff around my steering wheel isnt working...
Evening chaps,
Just been out for a quick drive and noticed that a few bits around the general steering wheel area aren't working...
Cruise control doesnt appear to work
Windscreen washer jets dont work
Headlights - side lights/dip beam works fine, but main beam doesnt stay on - you have to hold the stalk to keep it on
The car came with a Momo steering wheel fitted and not the stock one... could these problems be due to an incorrect Boss being used? OR is it more likely to be something else?
Any advice please?
Alex
Cruise control only works above 40mph, also make sure its plugged in inside the engine bay (just follow the cable back from the throttle cover to a large domed type object)
Sounds stupid but have you tried pushing the stalk both ways, one way it flashes the lights, the other it puts them on permanently.
For the washer, id check the fuse.
thanks, I'll have a look at the weekend.
Nb, I was testing the Cruise on a dual carriageway about 60-70 and sometimes it flashed and sometimes nothing happened even though the light was on?
I forgot to add, the Hicas light intermittently comes on for no apparent reason every now and again, even after its been topped up with liquid. I've heard this can be due to an incorrect boss.
check the electric in the foot well for corrosion and make sure the tagar drains are working OK (i.e. draining to the outside of the car)
you can check the fuses while your down there (as advised above)... :)
