August 18, 201214 yr Pretty self explanatory... Have a few bits that need sorting on my Zed, been in touch with Jeff at Zedworld but thats about 2 and a half hours away from me. Does anyone know of a place closer to me? Within about an hours drive or so? I'm based just west of York. Thanks Alex
August 19, 201214 yr Hi, Zedworld is the ONLY Zed specialist in the country!!!! At the same time, they have heaps of bits for Zed's and you pick up anything you're car is missing. 2 hours isn't really much for piece of mind. Worst case scenario, get them to find the issue and what needs to be done to fix it and then get that done later at a more local garage. there are probably other garages out there that can work on them and may do a good job but it really depends on the problems you have. If they have to replace parts no other garage will stock them and they will either order new from Nissan (a small fortune and a couple of days wait) or replace with the wrong or sub standard component. If the problems are a bit too Zed specific then there is little chance even a good garage will work it out.
August 19, 201214 yr Hi, Zedworld is the ONLY Zed specialist in the country!!!! At the same time, they have heaps of bits for Zed's and you pick up anything you're car is missing. 2 hours isn't really much for piece of mind. Worst case scenario, get them to find the issue and what needs to be done to fix it and then get that done later at a more local garage. there are probably other garages out there that can work on them and may do a good job but it really depends on the problems you have. If they have to replace parts no other garage will stock them and they will either order new from Nissan (a small fortune and a couple of days wait) or replace with the wrong or sub standard component. If the problems are a bit too Zed specific then there is little chance even a good garage will work it out. well said buddy im in whitby n yorks and will only use jeff at zed world after al as u said he IS the specialist
August 19, 201214 yr you may even find as i have that half your local non specialist garages will turn the zed away esp if its a twin turbo model. they dont want to get involved. and the only one locally to me who would get involved was a waste of time and money. there is jimmer with his company powerzed down south but thats even further for you. ive used zedworld for a few things now and ant fault them, your gonna have to travel to get your car worked on so it may aswel be travelling to someone worth their salt.
Alex
