Calling out for Jaikai (plus stance update pics if anyone interested)
Hi mate, got my new rear wheel situation sorted so no more shredding rubber and stance sorted so I'm back on the road.
Got a loan of a multimeter and set the TPS to 4.6v (was 3. something before I started), disconnected with ignition on (engine off) and plugged back in about 10 seconds later but still got a misfire/erratic idle and stuttering/hesitation when foots down. Are you available this weekend or next if I take a run through to try to narrow down the cause using your Conzult/datascan?
You can drop me a line at ??? or txt on ??? (please remove email and phone number once you pick this message up mate)
Stance before
Stance after
Edited by JaiKai
Aye typo, meant 0.46 vods :laugh:
Have you checked all the injector cables / ptu cables / CAS connectors for the green suff, you need to make sure they are all getting a good contact. also have you checked your timing?
Most if not all connectors cleaned up a couple of weeks ago, timing belt just replaced and new set of spark plugs etc (went in with this fault and came back out with it).
