Desperately require a PAS hose for my 1991 JDM N/A, one that comes down and across.
Can anyone tell from pic on ebay whether item http://www.ebay.co.uk/itm/380456749703?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D380456749703%26_rdc%3D1 is a hose for a N/A or TT, I did ask the seller who seemed unsure.
Your help as ever is appreciated.
Regards
Ronnie
Edited by groover
Should be the same for both iirc, its only the hicas connections and pot that differ.
An NA one wont fit aTT pump , but a TT one will fit a NA pump , the cranked metal tubular end that bolts to the pump has a different final length , the tt one being longer , so the NA one just doesnt quite reach enough to bolt onto the TT pump but fitting a TT one onto an NA pump is easy as it now has excess length on the pipe so drops on .
I found all this out at my expense after buying a na one for my tt . in the end i took my pipe off , took it to PIRTEK they made me a new pipe using the original fittings as they are specific to the car and it only cost £45 !! hth
http://www.pirtek.co.uk/
I have one. Only located it late tonite.
I will get more detail and picture tomorrow evening if you still need one.
Pics...........................
NA version I believe. No signs of any leaking and almost no corrosion.
PM to discuss/arrange.
