Service
Guys,
Looking at servicing and parts and want to know which are the correct and best with cost.
Front pads and discs best and costs
What is the best oil to use and filters
How often should transmission fluid be changed on an auto?
Where is the best place to buy parts?
I only ask as I see a lot of aftermarket stuff around ie ebay etc... and want to take care of the Z.
Also spark plugs
Cheers guys
Give MJP a ring and he will supply you with the right plugs and filters, pads and discs on ebay are fine, pads anything from mintex, ferrodo, brembo, but there are plenty of threads here about pads.
Discs and pads Grooved and drilled witn ferrodo pads Zedworld
15w x 40 semi synth any good brand name ( change every 3k to 4 k)
Nissan filter Zedworld
Every 2 years Dexron lll ( available motor factors)
Zedworld
Also spark plugs
Ngk Platinum Zedworld
Jeff TT
Discs and pads Grooved and drilled witn ferodo pads Zedworld
Zedworld
Also spark plugs
Jeff TT
Now there's the perfect answer to the question, well put Jeff :thumbup1:
