suspension
anyone know where to get my suspension sorted out please.got a problem with the camber.had 4 wheel alignment and was told that something is probably bent as they could not set the camber.so if anyone knows of a garage in the merseyside area preferably.
thanks
trev.
The camber on the front isn,t adjustable unless you fit adjustable top arms or a shim kit that shims the main upper arm mounting away from the inner wing to alter the camber .HTH
yes that does help.had a look at the on line manual and can see what you mean.looks like i'll have to invest in some adjustable top links.can't see anything wrong with the top links at the moment,so maybe new shocks will allso help.
many thanks
trev.
thanks
trev.
Did you get a print out from them???? Showing what the camber is at present.
yes the print out shows that one side was ok with a reading of -1.25 deg.the other side shows a reading of -2.22deg.hope that helps.
