front pads
are there any other bits and pieces i need to buy (other than pads) to be able to change the front pads on my z32 uk
Make sure you have a pair of brake shims either side, 8 pad to shim retaining clips and double check the pins, if you have them anyway, use some copper grease on the rear of the pad and shim to prevent squeal.
Re use the ones you already have if complete, i was just giving you a list of what you should end up with when replacing the pads.
