OEM UK Wheels Tyres.
ok, so its said to use:
225 / 50 / 16R on the front
245 / 45 / 16R on rear
Is there anywhere I can actually get four tyres the same brand and tread pattern?
What does everyone else have on their UK Spec OEMs?
Is there any harm having different fronts to rears?
The only Two I have found available in both the above sizes is the Bridgestone Potenza S02's
Rears: http://www.tyretraders.com/tyreInformation%7CItemID%7CBRI24545R16-ZRS02N3.html
Fronts: http://www.tyretraders.com/tyreInformation%7CItemID%7CBRI22550R16ZS02JZ.html
Which comes to around £480 for all 4 delivered (Not Fitted)
and the Toyo Proxes T1-R's
Fronts: http://www.tyrewizard.co.uk/car-tyres-c4/16-c19/toyo-proxes-t1r-225-50-r16-92w-tyre-p1974?utm_source=froogle&utm_medium=ppc&utm_term=toyo-proxes-t1r-225-50-r16-92w-tyre-2255016ztoyt1-r&utm_campaign=froogle#1974
Rears: http://compare.ebay.co.uk/like/400306553749?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&cbt=y
Which comes to around £450 for all 4 delivered (again not fitted)
Are there any others around? or is this my only options?
Cheaper at Camskill.
Fronts are £86 each, rears £105 - thats for the Toyo's
Maybe even cheaper elsewhere - it was the first place i looked
mate im having the same trouble best i could get was toyos £450 fitted ,,im going for unis on the rear and kumho on the front not the same running pattern ,but i have 4 225/50/16 on a set of bmw wheels in my garage so im going to just buy 2 245s for the rear only going to cost me £145 ,,rears will be zr but front will be 92s but i dont drive fast so they should be ok
Awesome Will check it out.
What tyres were they?
i had a set of Khumos fitted to UK wheels a while back. Came from black circles at approx £285 ish plus fitting
Potenza S02 are a good tyre. These are serious cars, don't play around with toytown tyres.
I agree. I want decent tyres. I dont want cheapest, but I want best value for money, performance VS cost, but something that will be better in the wet too. Hence I looked at S02s and T1-Rs, not sure how the potenza S02's perform in the wet though.
as i drive mine like an old man as its only ever been out in the dry ,and never been over 100 ,,,top of the range tyres are not somthing i would pay out for but it suits my wallet
Well I had the warning beep for the first time since buying the car saying I was over 110kmph lmao.
